How to modify model tab ?
anicot
I would like to modify the display of the model tab. in CreoView -> Screenshot in attachment.
In fact I would like to add 2 parameters in the same line.
In order to do it, I need concerned parameter I want to add in this line. So, I have it!
I'm able to add one parameter. But I'm not able to add 2 parameters.
So, I modified "admin_prefs.xml" like that to have at least 1 active parameter.
"category name="Navigation">
   <preference name="enable_preselection_highlighting" value="False"/>  <!-- Désactive la présélection -->
   <preference name="navigation_model" value="pro/engineer" locked="true"/>  <!-- Choix du type de navigation -->
   <preference name="alt_part_name_enable" value="True"/> <!-- Modification de l'arbre modèle: position + code article -->
   <preference name="AltProp2Group" value="__treeFilterPartName"/>
   <preference name="AltProp1Group" value="PROE Component Parameters"/>
   <preference name="AltProp2Name" value=""/>
   <preference name="AltProp1Name" value="Line Number"/>
   <preference name="AltText3" value=""/>
   <preference name="AltText2" value=" - "/>
   <preference name="AltText1" value=""/>
  </category>"
I don't know if it's possible to add more than 1 parameter in this line.
What do you think about ?
0 REPLIES 0
