Hai All,
I have written a code to open a creo session and set working directory using vb.net. and the code was working fine for me. now i trying to open a blank new assembly sheet using VBAPI
But i am getting some error, and i not able to get pass it, i went through the document but didnt get any help.
I am pasting my code over here.
Imports pfcls
Public Class Form1
Private asyncConnection As IpfcAsyncConnection
Private basesession As IpfcBaseSession
Private descModel As IpfcModelDescriptor
Private descModelCreate As CCpfcModelDescriptor
Private model As IpfcAssembly
Private session As IpfcBaseSession
Private Sub Browse_Click(sender As Object, e As EventArgs) Handles Browse.Click
OFD.Title = "Creo Parametric"
OFD.FileName = "xtop"
OFD.InitialDirectory = System.Environment.CurrentDirectory
If (OFD.ShowDialog() = Windows.Forms.DialogResult.OK) Then
CreoPath.Text = OFD.FileName
End If
End Sub
Private Sub btnBWD_Click(sender As Object, e As EventArgs) Handles btnBWD.Click
FBD.SelectedPath = System.Environment.CurrentDirectory
FBD.Description = "Select Creo Parametric working directory."
If (FBD.ShowDialog() = Windows.Forms.DialogResult.OK) Then
txtWD.Text = FBD.SelectedPath
End If
End Sub
Private Sub Start_Click(sender As Object, e As EventArgs) Handles Start.Click
Dim asyncConnection As IpfcAsyncConnection = Nothing
Try
If CreoPath.Text = "" Then
MsgBox("Please enter path to Creo Parametric executable", MsgBoxStyle.Critical)
Else
Me.Cursor = Cursors.WaitCursor
asyncConnection = (New CCpfcAsyncConnection).Start(CreoPath.Text, ".")
If Not (txtWD.Text = "") Then
asyncConnection.Session.ChangeDirectory(txtWD.Text)
End If
Me.WindowState = FormWindowState.Minimized
End If
Catch ex As Exception
MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
If Not asyncConnection Is Nothing AndAlso asyncConnection.IsRunning Then
asyncConnection.End()
End If
'lblStatus.Text = "Error occurred while starting new Creo Parametric Session"
Finally
Me.WindowState = FormWindowState.Normal
Me.Cursor = Cursors.Default
Me.Refresh()
End Try
End Sub
Private Sub NEW_01_Click(sender As Object, e As EventArgs) Handles NEW_01.Click
descModelCreate = New CCpfcModelDescriptor
descModel = descModelCreate.Create(EpfcModelType.EpfcMDL_ASSEMBLY, "123.asm", Nothing)
model = session.CreateAssembly("123.asm")
End Sub
End Class
the session which is highlighted in red is where i am getting trouble. Please help me to crack this
With Regards
Aghil.M
Hi Aghil,
what error message you recieve?
Tom
Hi Tomas.
Thanks for the reply, i got the solution for this.
and sorry for the late reply. i have posted a new question if you know anything about it, please guide me on that.
With Regards
Aghil
ok
