How to override cell in repeat region
SD_14219997
I am using creo parametric 10.0.2.0
I have a schedule in my drawing that is using a 2-D repeat region to call out my family table and insert a table with the following:
                           |  fam.inst.param.name  |                           |                            |                            |
fam.inst.name |  fam.inst.param.value   |                           |                            |                            |
         |  A     |  B       |  C      |  D      |  PART_NO  |  REMARKS  |
  -1   |  0.5   |  0.5   |  0.5   |   0.5  |  150QS01       |  NONE         |
  -2  |   0.2  |   0.2  |   0.2  |   0.2  |  150QS02       |  NONE         |
I hope that is good enough for anyone to understand what I am doing as I cannot share my actual data.
I want to override one of the fam.inst.param.name cells.
ex: the "PART_NO" cell, I want it to say something like "PART #"
I had seen that using the relations is the way to go but I tried writing something like this:
IF fam_inst_param_name == "PART_NO"
repeat_override = "PART #"
ELSE
repeat_override = fam_inst_param_name
ENDif
I then changed the fam.inst.param.name cell to rpt.rel.repeat_override using the User Defined option but it does not work.
Any help is appreciated as this would unlock a ton of possibilities for my team.
BenLoosli
(To:SD_14219997)
The header cells cannot be changed by relations.
If you are trying to replace the 150QS01 or 150QS02 with PART #, then you need those values in your IF statement.
As it is formatted now, you are looking for a string 'PART_NO' and not a variable name.
9 REPLIES 9
BenLoosli
(To:SD_14219997)
I see.
But now shouldn't it find the string 'PART_NO' in the headers row and change that? Seems like a dumb way to program it, but what do I know lol.
Can I set the repeat region to NOT include the headers? I don't mind typing in each column headers. I tried doing this as well but I don't think I was setting the region correctly and the existing documentation on how to use repeat regions is honestly atrocious.
Why not just rename the parameter in the model?
I tried but 'PART #' is not a valid name apparently, unless it is and im actually just dumb
Hi @SD_14219997,
Anurag
hi @anursingh
i marked the best answer as solution as it answered my original question but i also want to mark the answer this comment is under as an alternative (albeit not quite spot on but no matter it still helped me learn) solution to my question, is this possible?
BenLoosli
(To:SD_14219997)
Not possible to mark more than 1 answer as the solution, but people who look at the thread will see all of the comments.
One... "White Space" is not allowed in Part Numbers. Replace white space with "_". One can have "Part_"
Second: Not sure if Special Character "#" is Allowed.
Regards
Srinivasan Iyer
you can use following non-parametric "solution".
  • move table containing 2-D repeat region outside of drawing frame
  • export table containing 2-D repeat region to csv file
  • import csv file into drawing to get dumb table
  • modify table contents according your needs
Martin Hanák
