Before to create Geometric Tolerance in part model, I set a datum axis first. Properties -> Type: Set feature frame -> Placement: On Datum, In Dim, On Geometry, In Gtol. but there are no shown up dimensions in model, how to pick a dimension?
If I'm not mistaken, if you select IN DIM, then you actually screen pick on the feature with the dimension that you want to attached the GTOL to, it will display the dimensions for that feature.
You are right! I revolve, draft, round, and create GTOL in last step. The diameteres of revolves can't shown up during In Dim Pick Dim.... After moving GTOL before draft and round, it work well as you said.
Thank you very much!
Have a good & warm weekend! (after long winter if you are in midwest ....................
