My problem is, we have old models (Made in Creo 2.0 or Creo 4.0) but now we moved to Creo 9.0.4.0 and we moved on to new company standards, which means a lot of new parameter, and relations.
But with old models comes a problem, which is, we often can't delete parameters or make new ones which are restricted.
The problem most likely comes from the old model having a different restriction table than the new one.
I think the easiest way would be to make a macro to move all the features to a new template somehow but it comes with a different set of problems.
Is there anyone who figured out a good way to pass this problem?
You need model check. If you haven't used it before this book is a good start:
https://www.amazon.com/Re-Use-Your-CAD-ModelCHECK-Handbook/dp/1532940106
I don't have direct experience with that issue, but maybe this can help: https://www.ptc.com/en/support/article/CS62021?source=search
We use Smart Assembly from SIGMAXIM and wrote a update script that any user can run.
https://www.sigmaxim.com/index.php/products/configuration-tools/smart-assembly
