How to reduce the File Size while converting into STEP Format
rrangaswamy
7-Bedrock
While Converting my assembly (400MB) into Step format, the file is getting almost doubled (850 MB).
I tried both Solid / Surface Options, Still I am getting bigger File size
Can you please help me to reduced the FILE SIZE
Ram
1 REPLY 1
If you ZIP the file after converting to .STP format. that could be one solution.
