How to rotate 3D part with arrow keys?
kpedersen
How to rotate 3D part (for example 15 deg) with arrow keys?
1 REPLY 1
you can create mapkey to rotate model 15 deg using Reorient dialog box (Dynamic Reorient). Unfortunatelly you cannot assign it to arrow key (I guess that).
mapkey uu ~ Select `main_dlg_cur` \
mapkey(continued) `igToolbar_AncestorIGT_IGT_GRP_inh396938342.proe_win:casc340798662`;\
mapkey(continued) ~ Close `main_dlg_cur` \
mapkey(continued) ~ Command `ProCmdViewOrient` ;~ Open `orient` `SetupOptions`;\
mapkey(continued) ~ Close `orient` `SetupOptions`;\
mapkey(continued) ~ Select `orient` `SetupOptions` 1 `dynorient`;\
mapkey(continued) ~ Update `orient` `spinPH.YSpinBox` 15.000000;\
mapkey(continued) ~ Activate `orient` `spinPH.YSpinBox` 15.000000;~ Activate `orient` `OkPB`;
MH
Martin Hanák
