How to route multilevel cables in 3D
glászló
Hi!
I can't route wires in 3D jet (see my other discussions), but I can route cables. So now I'm trying to get it work properly. I've tried to route a multilevel cable (I've used the one from the sample catalog, for a test), and Creo can't display the outer insulation, of it. As shown on picture, it cant find routing points, but it doesn't allow me to define routing points either. How is it possible, to route it correctly?
The design:
The 3D:
As you can see, it only shows the two inner cables.
Lac
Lac
Read this topic from the help center.
Please note you will have to add the overbraid icon to the ribbon
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/electrical_design/To_Modify_Overbraids.html
Thanks, Jim
Lac
Thanks, Jim
