How to scale a model in Creo
ps-4
I was trying to find out if it is possible to scale a model in Creo to a 1:1 ratio? If so, how would I go about doing that?
5 REPLIES 5
BenLoosli
23-Emerald II
(To:ps-4)
Look at your list character by character across.
D01-XXX-1 comes before D01-XXX-3.
Typical computer sort problem that has always existed and always will.
Instance name is text string and therefore names are sorted alphabetically.
Martin Hanak
Martin Hanák
bshepherd
(To:ps-4)
If you want it to sort properly the names need to be:
D01-XXX-092
D01-XXX-030
D01-XXX-050
D01-XXX-105
D01-XXX-076
ps-4
(To:bshepherd)
Thank you Ben, I will request to my customer for changing part numbers as your suggestion
Mahesh_Sharma
22-Sapphire I
(To:ps-4)
Prabhu,
Mark the appropriate reply as correct answer. Or you can add you comments to post and mark that as correct answer.
