I am having Imported part in Pro/E (Import Feature).
Out of it I have created drawing.
It by default gives magenta colour, I wanted to change it to another colour.
upon right click "Line style" option is not available.
Image is attached for your reference.
The magenta color indicates the import is a surface model, not a solid. My first suggestion would be to solidfy the part as that would change it to the normal color scheme.
Thanks for suggestion, I will try and let you know the result
