Hello. I am new to Creo and Ive been creating flat patterns using a family table. The bend notes do not show up even though they are turned on in options under sheet metal/bend notes display settings/show bend notes. The tangent bend lines show up however. How do I get the bend notes to show up? Thanks
Hello Kenneth Paiva
welcome to forum. See following picture and notes.
1. set desired drawing model active
2+3. show model annotations in desired drawing view
4. show the model notes
5. show bend axis
6. GREEN color --- move your note als you wish (use mouse
Just a tip:
If you are looking for some functionality (icon) try following:
1. right up COMMAND SEARCH
Hope it can helps
Regards
Milan
Hello Kenneth Paiva
5. show bend axis
Just a tip:
Hope it can helps
Regards
Milan
I had been in that area but didnt know what to click. That worked. Thank you.
