Trying to show text from 3 parameters that are included in a part family table in a single cell that's part of a simple repeat region in a table on a family table part file drawing. How does reference a family table instance part parameter in a simple repeat region relation?
I have found examples of referencing assembly members but not part file instances.
Example of what I want the address cell to look like
How table currently looks
Example of repeat region relations not working
Appreciate any help you may provide,
Don A.
Creo 8 sample files attached
I modified your Table 1 and created Table 3, Table 4 (these are modified copies of Table 1).
Then I copied Table 1 to Table 5, Table 3 to Table 6, Table 4 to Table 7.
Finally I moved Table 5, Table 6, Table 7 so they overlap. A large zoom is required when moving the tables.
Modified data attached.
"A large zoom is required when moving the tables"
I would suggest selecting each table and use Move Special
Select the top left corner and enter location values.
I had to Customize LMB menu and to add Move Special command into it.
Hi Martin,
Sorry for the delay getting back to you.
Your solution works, but I ended up not storing the address data in the family table due to a new requirement for this drawing where there may be more than one vendor approved for a part in the table. Also more vendors and their part numbers may be added in the future for one of our part instances in the table and the address for the approved source may also change over time. This will make it easier to maintain for new users.
Thank you,
Don A
