While taking print out of drawing the template borders are going out of the page plz see attachment(1).
While exporting the drawing into pdf the borders come perfectly but the drawing lines are too thick plz see attachment (2).
before you save a drawing as PDF you have to put following options into config.pro file.
use_8_plotter_pens YES
pdf_use_pentable yes
pen_table_file PATH_to_pentable_file
1.pdf ... you can set X-offset Y-offset before you print
2.pdf ... I can't recognize thick lines
I opened your pdf files and set 800% display.
1.pdf
2.pdf
My guess ... you use two different pen tables, because the line thickness is different.
Thanks.
Thanks.
