Hello Everyone,
I don't know this is a right place to ask this question. But anyway here it goes.
I use Creo Express View 2.0 to open assembly model, but all the surfaces are turn on. This problem only happened with the models or assemblies that are created in creo 2.0 (the models or assemblies are created in WildFire 4.0 are fine.)
Any help will be greatly appreciated.
DV
Hello DV
I tested your files a little bit...
I uploaded 74215_bd1.zip...
74215_bd1.prt.53 ... saved in Creo Parametric 2.0 M030 by you
74215_bd1.prt.54 ... saved in Creo Parametric 2.0 M050 by me (no config.pro used)
There are two alternatives:
Good luck
Martin Hanak
Hello Vladimir,
Thank you very much for the hint. However, I've already tried that and it did not work.
DV
Donovan,
can you upload test files ?
Martin Hanak
Hello DV
Good luck
Martin Hanak
Hello Martin,
Glad to here back from you.
I did try the option #2 frist. which I launched Creo 2.0 without confing.pro and resaved the model, but that did not help.
Then I opened the model saved in Creo 2.0 M050 version ( which was sent and created by you) and it works.
Look like I have to install the M050 version.
Thank you very much for your help Martin.
DV
