Hello, I have a problem for pipe design,
I use pipe application to create the 3D model normally .
Our systems can used in different industry areas,
Most times we only need to change the brand of those componets, and use same pipe line.
I guess maybe we can use configurable product to make pipe design?
So I can easily add or change the brand.
Seems pipe application cant insert configurable product or configurable model.
Would anyone try this before?
Hi Sulibo,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
Hello @vnamboodheri ,
Thank you for your advice.
My questions are:
Does "Configurable Products" module compatible with "Piping" module?
Have anyone tried use these two modules in same time before?
And how about the result, feeling good or bad?
Br.
ps.
Sorry I need links to explain words for:
Configurable Products; Piping module
Thank you!
