This what I know so far........
Within the Creo CAD assy, I can goto file > prepare > model properties > click change next to mass properties.
Then click generate report, the window will appear with all immediate components info.
The question is.....anyway to see the components children info as well?
Hi Brad,
Try setting the config option mp_calc_level to all_models and then generate the mass properties report.
Amit
Hi Brad,
Amit
Yep, that worked, thanks!
