I created a sheet metal asm, added the prt and created the _flat. Now I have a drw ortho with the flat on the model tree but not on the drawing. What did I do wrong and how can I fix this w/o starting over?
I think you need to regenerate your drawing and update also.
Actually if you can describe your question briefly, it would be better to answer. Adding images would be advantages.
Jitu
