I fixed the sketch and successfully made a wrap, i want to extrude this exact shape outwards.
Is there a way to extrude this wrap?
Extrude is only a linear operation in Creo and does not work around a curved surface. You will need to trim a surface by the sketch and thicken the surface (as shown in examples in previous discussion). From your image, it appears you have a solid. You can change the solid into a surface or copy the outside surface and remove the solid.
If it isnt possible to extrude a wrapped sketch. Is it possible to curve a sketch then extrude it? or curve an existing extruded sketch?
The closest thing to what you are describing is the thicken operation:
It looks like your other discussion is getting a lot more traction in getting an answer:
