IFX error message when placing bolt and nut in Creo 11
jndejak
After choosing a bolt and corresponding nut, I get the attached error.  The hole in the first part is created, but the hole in the second part of the bolted assembly does not get created.
Hi @jndejak,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
