I am attempting to rename an assembly that contains flexible components. Can I rename/copy without first removing the flexibility? The OK button is greyed out and a component I did not change has an issue.
NO YELLING IN THE HALLS PLEASE ![]()
I can save-as an an assembly with a flexible component.
And I can rename the newly created assembly where the flexibility was preserved.
You might be having a naming issue rather than a flexibility limitation.
