IS IT POSSIBLE TO COPY ASSEMBLIES CONTAINING A FLEXIBLE COMPONENT?
spete
I am attempting to rename an assembly that contains flexible components. Can I rename/copy without first removing the flexibility? The OK button is greyed out and a component I did not change has an issue.
TomD.inPDX
(To:spete)
NO YELLING IN THE HALLS PLEASE
I can save-as an an assembly with a flexible component.
And I can rename the newly created assembly where the flexibility was preserved.
You might be having a naming issue rather than a flexibility limitation.
TomD.inPDX
(To:spete)
