ISO tolerance table
prosa
8-Gravel
ISO tolerance table
Is it possible to have the ISO tolerance tables always loaded(avoiding the step of retrieving the tables) ?
With this I can reduce a step in drawing process increasing the productivity.
MartinHanak
(To:prosa)
I am not sure what note are you creating in a drawing.
Load ISO tolerance tables must be done in model, see following picture.
MH
Martin Hanák
6 REPLIES 6
MartinHanak
(To:prosa)
  • open model template
  • change tolerance standard to ISO
  • load ISO tolerance tables
  • save model template
  • use model template to create new model
MH
Martin Hanák
Thanks for your help.
The tolerance definition is already in ISO/DIN. But when i want to create the note on 2D draw i have always to retrieve the tables. I want to know if there's a way on config.pro or in other file to have the tables always available.
MartinHanak
(To:prosa)
MH
Martin Hanák
Ok, I always do that as you shown on the picture before.
For example, i'm a designer easily a machine in my projects have more than 100 parts, do i have to do this 100 times or is there a way to do it just once.
MartinHanak
(To:prosa)
YES, you have to do this 100 times.
MH
Martin Hanák
