Imported step file, the blue comment can not be hidden / removed
rsu
When I Import a step file, the blue comment can not be hidden / removed.
Hi Robin,
Were you able to place them on a layer?  Also, if nothing is working, you may want to ask the person who sent you the STEP file, to export it without the annotations.
Amit
Okay, thanks, I try it.
It doesn't work as the method you mentioned.
And the comment disappears when i change a config.pro  file.
