Good Morning,
I have recently started using Creo Parametric 2.0. I am trying to import iges and step files into Creo and edit the features. Everytime I open the iges or step file in Creo I am unable to measure between two surfaces much less change any features on any of the parts within the assembly. Is there another way to import these files for editing purposes?
Robert
Right, you can only access .sec files while sketcher is open using the all files filter under the get data drop down.
There are many ways to do what you want, yet when you have FMX.
I'd get rid of that line in the hole, and place a datum axis there instead. FMX Move can move datums along with the geometry. Also FMX Mirror can mirror datums, which is pretty good.
For starters it's best to watch these:
http://www.ptc.com/appserver/wcms/events/online.jsp?&im_dbkey=158918&icg_dbkey=142
http://www.ptc.com/appserver/wcms/events/online.jsp?&im_dbkey=158975&icg_dbkey=142
Are they importing and solid, or are they broken quilts? The first step is fixing them to make them solid, if they are not.
I have had a ton of good luck with the flexible modeling. Even imports where I adjusted feaures that had a bunch of radii updated perfectly.
It also depends on what (and how many features) you want to edit.
I highlighted Component 164 after removing the block around the hole. Selected Repair, checked Repair Tangency and Ok. Is that what you mean by making it a solid?
No, using this method, I would exit out of IDD mode and then draw a surface over the top opening, then merge, then solidify. If the bottom is open (can not quite tell in the picture), then you have to close it with a surface also and merge it before the solidify.
Again, this is just one of the many methods of using this geometry, and in my opinion usually deciding how to use the geometry is trying to have some thought on how you are going to need to modify it in the future, which is how I tend to do all my modeling anyway.
