I imported a CAD assembly into Creo and now I want to export the assembly as a creo asm file. Would it be possible to export all files in that assembly as a creo part file? Please see the image attached. Also, I noticed that when I export it is only the assembly not the parts within the assembly is there a way around this or is this the extent of exporting?
Thanks in advance!
Your issue is two-fold.
