In Sketcher, how do you prevent yourself from dragging geometry with a hard dimension by accident?
MichaelWittig
Hello Folks,
When I am drawing geometry in sketcher, I've noticed that after I've created a "hard" dimension for a feature, I can still drag it larger or smaller, altering the "hard" dimension. Is there any way of preventing this with some setting?
Mike
By "hard" I assume you mean Strong. Strong simply means that you want to take the tentative dimension given to you automatically by Sketcher and give it the permanent parametric status of your design intent. In the same menu you get when you pick a dimension and hold down the Right Mouse Button is the option Lock. That's probably what you are looking for.
There is also an option to automatically Lock each dimension when you type in a value, instead of just making it Strong. We have this set.
You can still Unlock the dimension from the right-button menu if needed. I find this very useful for dragging sketches - leave all the dimensions Locked except the one(s) you want to change.
MGortner
(To:DavidButz)
You can also use the keyboard shortcut "control + T" to lock a dimension....a few milliseconds faster than using right-mouse button menu.
-Matt
Nice! I like keyboard shortcuts.
