In drawing, to the text as Subscript or superscript
ptc-1939138
Hai friends, I'm created a dimension and over the dimension text. In that, I want to show the text in form of Subscript or superscript. Not only for dimension text, is this options also I want show in note (text). Thanks in Advance, Balaji
"Balaji Krishna Kowru" wrote:
Hai friends, I'm created a dimension and Over write the dimension text. In that, I want to show the text in the form of Subscript or superscript. Not only for dimension text, and also for note(text). Thanks in Advance, Balaji
You can use this syntax for Sub/Super Script. TO SUBSCRIPT NUMBERS : @-123@# TO SUPERSCRIPT NUMBERS : @+123@# I have used 123 as an example. This should work for you. -Chander
thank u mr.Chander, its working. But it is effectively working in note(text) only. I want in dimension text also. i want Over write the dimension and give tolerance for that. and also decrease or increase text size of superscript or subscript value or text in the dimension. Balaji.
