In the Schematics, how the difference between the straight and flexible shape type of linestock
lcr
In the Schematics, how the difference between the straight and flexible shape type of linestock , is determined by one parameterWhich one
JimBarrettSmith
(To:lcr)
Assuming you are intending to drive Spec Driven piping then first you will require a flexible stock in the catalog
You will then need to add to you pipe group the parameters
  • Mnemonic
  • Schedule
  • Size
  • Spec
The value of the parameters need to correspond with the linestock in Piping design.
thanks, Jim
