Include the "@" symbol in a custom symbol
sfitzgerald
2-Explorer
I am using Creo Parametric Release 4.0 and DatecodeM110
I would like to include "@" symbol in a custom symbol but when i add the character it does not remain after redefining the symbol. Does this character require special handling?
Yes,
To use & or @:  Type twice in note e.g., && or @@ .
3 REPLIES 3
Yes,
kdirth
(To:kdirth)
& and @ are used for formatting in Creo.  Here is a list of text tips that I have documented:
  • Overwrite Dimension: @O
  • Box around text: @[***@]
  • Superscript: @+***@#
  • Subscript: @-***@#
  • Super/Subscript {0:***}{1:@+***@#)@-***@#
  • Multiple formats:
    • To edit the style of one section of a note, first click to select the entire note, then click again to select just the section you want to change. You can then RMB -> Text Style... and change size etc. as required.
    • This works directly with separate lines within a note, but to change just one part within a line you must first separate that section by adding {1: and } around the relevant text:
    • {1:Large Text} Small Text
    • Separate Line
    • Then close the note editor and proceed as above.
  • Round Parameter Value:  add [.X] after the parameter name, X being the number of decimals.
  • Leader Location on Note: add @O to line on note.
  • Use & or @:  Type twice in note e.g., && or @@
That worked. Thank You!
