Insert/Import Parameters to Existing Assembly
a_valle1
I wanted to know if there is anyway to import paramaters from an already existing assembly file to another. I know there is a way to import using a .xml but I don't have an xml file. What I mean is I have an existing blank .asm file with parameters already set up and I want those to be imported into an existing asm I already have which contains no paramters but the built in ones. I really don't want to have to restart this asm as it was very time consuming. Any suggestions would be appreciated.
tbraxton
(To:a_valle1)
Open the blank.asm and export the parameters as an .xml file. Import this .xml into the .asm file where they are needed.
Involute Development, LLC
Consulting Engineers
KenFarley
(To:tbraxton)
I'm working with Creo 4.0 here, and I found that you can open the parameters dialog, select all the ones you want to copy, then right-mouse-button Copy. Open the assembly/part you want to copy them to, open its parameters dialog, then right-mouse-button Paste. It will complain if any of the parameters are already in the target, but that's a good thing.
BenLoosli
(To:a_valle1)
They can be imported by using a mapkey.
Check out the attached file and modify for your own parameters.
Chris3
(To:a_valle1)
In addition to the other comments, if this is a systemic problem and not just a one-off you can look into implementing Model Check which can create and check the parameters for you.
