Insert a profile tolerance frame in note
Hongjie
I would like to know if it is possible to insert a profile tolerance frame in general note where all general technical requirements are listed, which like:
     UNLESS OTHERWISE SPECIFIED
          1. PREPARED IN ACCORDANCE WITH ASME Y14.9-2009
          2. DIGITAL DATA FILE INCLUDES FILLTS,CORNER RADII AND DRAFT
          3. VALUES QUERIED FROM PROE ARE BASIC
                              (here put a profile of surface)
I can insert / create a symbol (like surface finish) in note by &gym(symbol name in ProE lib), however I can not find a geometric tolerance in proe lib( symbol dirctionery). It is also possible to relate a seperated profile tolerance frame with general note but I prefer to directly insert it in note, which is more convenerience for move and edit.
thank you any instruction and have a nice day.
Best regards, Hongjie
You may want to check out this thread
Tips for text
specifically, page 8
2 REPLIES 2
Tips for text
Hi Ron,
Thank you very much to introduce so winderful thread, my problem is solved.
I am reading the thread with big small, all are kindly and good experts. On the other side it is boring job to search and read PTC help center.
