Inserting GD&T in the drawing - Issue
ArekTRI
I am trying using Geometric Tolerances - Annotations Tool within a drawing environment.
But I am getting the issue - STATUS: incomplete, please set placement in Model Refs.
The fact is, I have already set this entity, selecting desired surface.
the next issue I spotted is this tool is freezing when I try to Select entity or place gtol.
Any solutions guys?
Arek
Creo 3 user
6 REPLIES 6
Mahesh_Sharma
22-Sapphire I
(To:ArekTRI)
@ArekTRI
Can you share some steps or video for the steps?
ArekTRI
(To:Mahesh_Sharma)
Hi @Mahesh_Sharma,
the steps are:
Annotate Tab - Geometric Tolerances
Select Model - Select entity
then Place Gtool and nothing happens.
even I cannot delete the one GD&T dim I created before.
regards
Arek
Creo 3 user
Mahesh_Sharma
22-Sapphire I
(To:ArekTRI)
@ArekTRI
This may possible due to improper placement of Gtol (Specify placement in GTOl).
Mahesh_Sharma
22-Sapphire I
(To:ArekTRI)
@ArekTRI
BTW which dimension you are using for placement, I mean it is d, ad or add?
ArekTRI
(To:Mahesh_Sharma)
Hi @Mahesh_Sharma
thank you for your answer,
I am using Creo 3 for 4 months - I don't know what are d, ad or add?
Arek
Creo 3 user
Mahesh_Sharma
22-Sapphire I
(To:ArekTRI)
@ArekTRI
Check article CS41916
