I am not sure if this is what you are looking for or not, but Edit>Restructure allows you to move components from one assembly to another within the assembly context. I created a simple test, which was an assembly with a subassembly assembled as a component in the initial assembly. I was able to move a component from the subassembly and make it a component of the initial assembly. A couple of things to remember here are:
(1) you cannot move the first component of an assembly during the restructure process.
(2) I am not sure if your Pro-Program/ relations/ parameters etc. will carry over with the part as well.
Just thought I would throw this out there.
-Greg
