Is it possible to anchor a leader note to a symbol?
joe_morton
I'm trying to create a symbol in Creo for Grain Direction, similar to what's show in ASME Y14.8. It consists of a symbol that is placed on the geometry, with a leader note placed outside of the geometry, pointing to the symbol.
I know I can have a leader go FROM a symbol, to an entity in the drawing, but is it possible to have a leader go TO a symbol? (And actually attach/anchor)?
See image attached
kdirth
20-Turquoise
(To:joe_morton)
Unfortunately Creo does not allow for creating a leader note in the symbol or attaching a leader to a symbol.  You can relate a leader not to a symbol, but the only thing that moves is the note not the leader.
I would suggest starting an Idea.  I would vote for it.
The "trick" I've used in the past to do this kind of annotation is when I create the leader note I attach it to the surface of the part near the marking I've applied in the model. It's not a perfect attachment to the marking, but I just want to make sure that if I move the view the note goes along, too.
I'm using Creo 4, by the way, hopefully whatever version you are using behaves in a similar manner.
kdirth
20-Turquoise
(To:joe_morton)
Another option is to use Relate to Object and attach it to the view.
kdirth
20-Turquoise
(To:joe_morton)
Dale_Rosema
(To:joe_morton)
Searching for something else, I came across this. Don't know if it will help or not:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Attach-note-leader-to-a-symbol-leader/m-p/139733
Thanks all for your suggestions. This helped confirm for me that what I was trying to do isn't really possible.
I created an idea here: https://community.ptc.com/t5/Creo-Parametric-Ideas/Allow-note-leader-to-anchor-to-a-symbol/idi-p/728519#M14297
