In draw mode, I like to work with a black background and the crosshairs are currently red. Where or how do I change the color to white?
Thanks for any help you can give me in this regard!
Bill,
in Drawing mode when you sketch 2D geometry, you can see a crosshair. Its color is driven by Primary highlight system color. You can change it from dark red to white (as shown on the picture). Unfortunatelly this change affects other Creo "areas".
Martin Hanak
Bill,
Martin Hanak
Martin, that's exactly what I wanted. Thanks so much!
