Is it possible to reference these 3 holes about this large center hole?
jhorst
7-Bedrock
I'm working in Creo Parametric 2.0. With the picture presented, is it possible to make those three smaller holes use the larger center hole as reference, so if I want to move that center hole, the rest move with it? I'm using the Hole feature, not just extrude-cutting three holes through the surface.
TomD.inPDX
(To:jhorst)
The concept is that you want to place the hole radially about the center hole's centerline (angle and diameter).  After that, you can pattern the other 2 holes.  I recommend this as this is how you can get a radial bolt pattern centerlines to show up in drawings... but you also have to enable that in Detail options:
4 REPLIES 4
Here file you need. Try to see if it works as you want.
TomD.inPDX
(To:jhorst)
That's pretty much exactly what I was looking for, thanks! It did the trick.
TomD.inPDX
(To:jhorst)
Happy to help, James.
