Is there a possibility to convert an assembly to a multibody part in CREO 10
DILIP88
6-Contributor
Hi
I'm using Creo version 10.0.3.0
Is there any possibility in aforementioned version of Creo to make multi body part from the assembly.
thanks & Regards
Dilip
@DILIP88 wrote:
Hi Vladmir
Thanks you for the reply.
Unfortunately i was not able to find the config.pro option intf3d_in_as_part.
this option is hidden.
You have to open config.pro in Notepad, add intf3d_in_as_part yes at the end of file and save.
Restart Creo.
Martin Hanák
3 REPLIES 3
VladimirN
(To:DILIP88)
DILIP88
6-Contributor
(To:VladimirN)
Hi Vladmir
@DILIP88 wrote:
Hi Vladmir
Restart Creo.
Martin Hanák
