Is there a way to get rid of this info from the model window
pkane
Hi All,
Is there a config.pro option or another setting to get rid of this info from the model window.
It is present in mechanism design, so when I run and capture an analysis, it is present in the mpg file. I dont need this information displayed in the recorded analysis.
Any ideas?
11 REPLIES 11
TomD.inPDX
(To:pkane)
Your image did not come through.
Please place the image on your computer and then navigate to the location with the image UI.
pkane
(To:pkane)
TomD.inPDX
(To:pkane)
Now the image shows up
...but I don't have an answer. Somewhere I thought there was a solution. However, when I capture mechanism or animations, I don't get this in the screen. I am using the "play" dialog to access capture.
How are you capturing this?
By selecting the playback from the model tree.
RMB select play. ( brings up the animate dialogue box.)
By selecting capture from this dialogue box.
I use MPG file format cos this seems to be the smaller than AVI.
BTW. This info is always present, when modelling. ( in the left bottom corner of the screen). It changes depending on the features ( simplified rep, instance etc) in the model. It seems to always be on screen.
I just want to find a way to turn it off , would be best. then I dont have to crop it out when sharing screen images either.
Message was edited by: Paul Kane Using Creo2 M080 if that should have any bearing on this.
mbrockman
(To:pkane)
an easy way is to change the text color to match your background, and voila!!!
pkane
(To:mbrockman)
Hi Mark,
More info please, how do i find that particular text, is it under system colors?
system color - option graphics, if so letter is set as default blue and makes no difference changing this to the background color.
Hi Antonius,
I note that if I capture the analysis and select the check box for photo render frames, I dont get the on screen info in the mpg output file.
However doing it this way, it takes so long to capture the 1 minute analyses at 25 frames per sec.
TomD.inPDX
(To:pkane)
That is weird. It doesn't do that on mine.
The only thing I have to remember to turn off is the chronometer in the upper left corner.
What build of creo2 are you using?
TomD.inPDX
(To:pkane)
M040
