Seems like it should work. I do something similar from a startup script with the cache location, but it should work the same way in the PSF file.
set PTC_WF_ROOT=C:\ptc\%USERNAME%\WC12_CP4_WGM
Excellent! Thanks for the help. It works perfectly.
