Japanese language symbols don't show up on my drw notes?
cmaass
Hey community,
I have some drawing files with updates and when I go to print to PDF the notes with Japanese symbols show up as blank squares.
I attached a picture, anything anyone can do would be great.
6 REPLIES 6
MartinHanak
(To:cmaass)
1.]
You can stroke all fonts when exporting PDF. Creo transforms letters into lines and PDF will contain correct output.
2.]
If you do not want stroke fonts, then you can set PRO_LANG variable to japanese, launch Creo and export PDF.
3.]
If you do not want to set PRO_LANG variable, then you need to add config.pro option intf2d_out_pdf_unicode   yes and use specific Creo release, see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS153898
Creo 2.0 M140, Creo 3.0 M020, Wildfire 5.0 M260
MH
Martin Hanák
I chose to use the config.pro option, but how do you set the "stroke all fonts" when exporting to PDF?
MartinHanak
(To:cmaass)
you can set "stroke all fonts" option:
  • manually in dialog box displayed during PDF export
  • automatically using config.pro option INTF2D_OUT_STROKE_TEXT ALL
MH
Martin Hanák
hi Cameron,
1: reconfig the creo to add the japanees font while installing it,
2. Important thing is Go to Control panel - Environmental variable- edit environemental variable-system variable-add new-variable name and variable value,. Variable name: "LANG" (must be caps)
        Variable value  'japanese" (mut be in small).
it work out for sure,
reach me if it is not.
Chethan
Cameron,
can you see Japanese characters when you open drawing in Creo ?
MH
Martin Hanák
did u tried this??
