Hello, I installed Schematics 8 and even though it is giving a java error when opening, I followed the link below and still with the same error.
https://www.ptc.com/en/support/article/CS337054
Hello ,
I did but it didn't work, I had to remove the java again and put it there it worked, but thank you very much for the feedback.
Did you follow these instructions during installation?
Article - "Install Creo Schematics 8.0 step by step": https://www.ptc.com/en/support/article/cs359613
Hello ,
