Laser cutting spline lines
RyanVanVeen
I am using Creo Parametric - Release 3.0 (connected) 3.0 M040
When we create sheet metal parts to be cut on our laser, many have complex splines, rather than smooth arcs. Is there a way to have Creo export DXFs from the drawing with best fit curves and arcs rather than splines and polylines?
5 REPLIES 5
tbraxton
(To:RyanVanVeen)
Try setting this config option to yes. This should export the splines as arcs using a DXF output.
intf2d_out_splines_to_arcs
This will not necessarily fix everything as it applies only to splines that represent arcs.
Description: Yes - splines geometrically representing arcs will be exported as arcs. No - such splines will be exported as splines.
If this does not address the issue you will probably have to use a 3rd party application to convert the splines to arcs in the DXF exports.
Involute Development, LLC
Consulting Engineers
Seems to be a problem that has been asked about before:
Export DWG Drawing with Converted Splines to Arcs
Is it possible to output a spline as lines and arcs when export drawing to DXF in Creo Parametric
Doesn't seem to be an option. The options available when doing a DXF export are not helpful for this situation. You can specify splines be saved as polylines, but not approximate lines and arcs.
RyanVanVeen
(To:KenFarley)
I was hoping that there was some development since that previous discussion (2012).
I'm going to try "intf2d_out_splines_to_arcs"
I had checked the config options for DXF but not the general intf2d_out options. Hopefully that will help, but I have my doubts.
RyanVanVeen
(To:KenFarley)
Your doubts are well founded...
This setting was already set to "Yes" by default.
I'm thinking that we will need to post process these files somehow, I just do not know what software is available for this.
