Layer problem in Drawing in Creo 2.0.
ssharma-6
2-Explorer
Layer of views is not showing in layer tree by the selection of active layer object selection.
for more hint please the attachment.
Thanks in Advance
Sachin
  1. activate Layer tree
  2. click Setting button and then Drawing Layer Status command from context menu
  3. check both options (see picture below)
  4. click arrow button and select any drawing view
  5. expand view list ... now you can see views, too
MH
Martin Hanák
7 REPLIES 7
StephenW
(To:ssharma-6)
What exactly are you asking? When you use the selection arrow, that allows on-screen selection.
When you use the drop down arrow, then you see the views.
When I use drop down arrow, then display assembly's views name only. There is no drawing view name like bottom_4, left_12 etc.
kdirth
(To:ssharma-6)
May be a very old drawing or copied from an old one.  I happened to pull up a drawing redrawn in ProE in 2004 and saw the same thing.  Pulling up a drawing created this year it worked as expected.
kdirth
(To:kdirth)
The only way I found to get the views to show up was to add a new view and delete it.  Somehow this triggered the views to be added to the layer tree.
MH
Martin Hanák
Thanks Martin
This is right way
Dale_Rosema
(To:ssharma-6)
If Martin's answer was correct, don't forget to mark it for those who may search on this topic later.
