Is there a way to modify the end of this wire so that it's in line with the other one (red). and follows those? dots?
Also has anyone experienced manually routing a wire and once a new segment has been made it lays itself directly on top of something that has already been routed?
Flattening seems to be really tricking and annoying a lot of the times the wires won't move in the plane that I want when trying to put them right beside each other. No matter what I mess with nothing really seems to change how the segment reacts. There are also times that I use the move segment tool and if i move it to far from the original position the segment disappears and the segment in the model tree goes red and I can't undo it I have to flattened that segment again.
Hoping someone can shed some light on this as its really frustrating to deal with.
It might help if we knew the logical diagram of the cable you are trying to do.., something as shown below...
Normally when routing wires and cables
Your flat diagram didn't show any connectors?
Br,
Lars
Hi @AL_13006242,
Anurag
