Line Continuation Character in Pro/PROGRAM Inside Conditional Statement?
pwilliams-3
All,
I have a drawing program that contains a conditional statement ("IF" statement) that needs to check the value of 9 parameters. However when I put all 9 criteria in the IF statement and save the program ProE truncates the line at 81 characters and fails to parse. Ok no problem I'll just put the backslash " line continuation character at the end and continue with the rest of the criteria. When I do that then ProE fails to parse the conditional. Has anyone solved this issue? Here is the conditional statement:
LH_INTERPORT:0 == NO & RH_INTERPORT:0 == NO & CNTR_INTERPORT:0 == NO &IF LH_INTERACT:0 == NO & RH_INTERACT:0 == NO & CNTR_INTERPORT:0 == NO
SET STATE BLANK-SHEET
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
On a recent design, I had this problem. I solved it by making sure that
the "\" was inserted between conditional statements. See below:
IF PITCH=="03"|PITCH=="04"|PITCH=="05"|PITCH=="06"|PITCH=="07"\
|PITCH=="08"|PITCH=="09"|REL_MODEL_NAME=="1024T_01_ST"
Robert Hills
Cooper Tire & Rubber, Co.
(419) 427-4909
- <">mailto:->
