In Creo View version 5.x the lines on the aforementioned 4K-monitor are extremely thin (I assume the same would be true for Creo). This is especially the case for HLR view. The screen is a 4K monitor measuring 24" and having 196 dpi.
Is there an option in Creo View to increase the line width? If not, I suggest adding this, because the lines on high-resolution devices simply get too thin if kept at one pixel line width.
Unfortunately there is no answer on this issue, therefore I shall give the topic a friendly *bump*
Anyone...?
Still no line thickness option in Creo View 6.0?
Also, is there a way to increase the line thickness when exporting model views to image files? There is no point in generating a high quality antialiased image file with multi-megapixel resolution when all lines are 1px wide and therefore almost invisible!
*polite bump*
Is there a way, or are there any plans, to adapt/increase the visible line thicknes on high-dpi devices, e.g. on 4K monitors?
Thanks for letting the community know
@VeqTor wrote:
*polite bump*
please contact PTC Support and ask them directly.
Thank you. I did so and hope that they will care.
(the issue is still unresolved on Creo View 6.0)
Would you believe that PTC support suggested changing Windows 10 DPI compatibility options -- in other words, use my 4K-Monitors with the (four times lower) FullHD resolution?
All,
I am running the new HP 15 Zbook with 4K screen and I love how sharp the lines are in Creo View 4.2 especially when viewing a drawing. So much better than the pix-elated words in the notes that you had to pop out to read them better.
This is what I am running.
Yes, these are the exact same Windows DPI settings as the ones I am using, and the sharpness of the image is of course fantastic -- also in Creo.
However, this does not help with the problem initially described -- that the lines (at least in HLR view mode) are microscopically thin. See my screenshot, or try for yourself with HLR view mode on your Zbook.
Apparently, these lines are displayed with a width of exactly one pixel regardless of the screen dpi resolution.
*bump*
After years still no way to adjust line width in Creo View!
Please FIX!
