We have the original manufacturer part number as a parameter in the Windchill wt file. I need to get that information into my drawing BOM. How can I go about this? Using Creo 7.
You can map the Windchill attribute to a Creo Parameter and get it into your models and then from there show the model parameter in your drawing.
Hi DC_9981462,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
