Links between large displacements
DenisJaunin
I try to represent the deformation chain three discs.
Dimensions are in millimeters.
Load [N / m ^ 2] is uniformly distributed.
"Green" disc supports load by deforming the "purple" disk.
In turn, the "purple" warped disc presses on the "green" drive.
I put the inner faces of the discs contacts and I chose the large deformations.
But despite the contact records, the deformation of the "green" drive is more important than the central disk without cause or remember.
Should I use another method of contacting faces.
Cordially.
Denis.
3 REPLIES 3
Could you add a screenshot of the analysys definition and one of the analysis result ?
Everything behaves normally in moving discs.
I remember the disc diameter 3 meters and 5 millimeters thick.
It's my fault, I put too large a scale.
In this case, the size distortions are not proportional.
At 1:1 scale well disks rely on each other.
Cordially.
OK, fine !
