MATERIAL DATABASE IN CREO 2.0
sholennavar
Hello ALL
IN Creo, when we try to assign a material to a part, we go to
FILE >> PREPARE >> MODEL PROPERTIES >> MATERIAL >> CHANGE.
After which it opens a tab of "MATERIAL DATABASE" , here we can define a new material of our or use the available material if already predefined.
So now i have many material (.mtl files) predefined in my server which i want them in this creo's "MATERIAL DATABASE".
So how do i copy them from my server to my creo's MATERIAL DATABASE?
Thank You
Regards
Sumeet
perhaps you can point to them using the config.pro option
pro_material_dir <directory>
2 REPLIES 2
BenLoosli
(To:sholennavar)
If you need to move them to another computer, just copy the files across the network or use a portable device (USB drive or CD).
If the files are on a network drive and you need all users to access the same files, use the pro_material_dir setting in your system-wide config.pro.
