Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I know how to put variable text in a symbol. That is not exactly what I’m looking for. So far, I have not been able to figure out how to drive those variable text fields with an attribute. Is that possible in Creo5?
